Can I eliminate the Pcv valve?
voltron_boi
Car: datsun z
I want to eliminate the Pcv valve from the valve cover, and rethread it to install -AN fitting.
My current setup now, I have a vacuum line from the intake manifold going into the pcv on the valve cover. It seen like I am having a air leak there, so my question is can I eliminate the Pcv valve and plugged it with straight vacuum coming from the intake manifold.
Btw I have oil catch already install, and have 1 line going to the valve cover and the other 1 to the maf pipe.
Something like this
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Yes you can.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Sure, depends on your method tho, you can also use a 1/2NPT interrupted tap and plug it
Bluefire
Dude, you will have an even bigger boost leak than before and may even blow out some seals, if you connect your intake manifold to the valve cover without a check valve. Do you understand what a PCV does? If you want to eliminate the pcv that bad, at least plug it off. Better yet actually fix the air leak you have now.
-Bluefire
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Bluefire wrote:Dude, you will have an even bigger boost leak than before and may even blow out some seals, if you connect your intake manifold to the valve cover without a check valve. Do you understand what a PCV does? If you want to eliminate the pcv that bad, at least plug it off. Better yet actually fix the air leak you have now.
-Bluefire
He is proposing detaching the pcv line altogether and running all thru a catch can and into the intake, not the intake manifold.
Bluefire
-Bluefire
I don't see that at all from his post. The way its worded it seems he wants to remove the PCV, rethread for an AN fitting and plumb to intake manifold. He also mentions he has a catch tank attached to the upper valve cover vents and to the intake, which is technically irrelevant to his original question. Maybe the OP should clarify his questions.
voltron_boi
Car: datsun z
Something like this, eliminated the Pcv valve and straight vacuum from the intake manifold. Picture below
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
that would not be correct you would boost the crankcase... Now if you plug the intake manifold hole, and the rocker cover you are good to go... infact... thats what I do
Darius
Thanks for being the patient one hahaha :facepalm:
voltron_boi
Car: datsun z
Block Intake manifold vacuum, rethread Pcv housing and install air filter. Everything else should be find how it is right?
s12god
Car: 1985 200sx 1990 accord
being that the rb26 already has oil surge issues wouldn't this be a bad idea?
Darius
It isn't necessary to have a PCV valve, but you can't leave the valve cover connected to the intake manifold if you remove it.
robbie2883
Car: 1998 RB25 Kouki
OutToWinPAHC wrote:that would not be correct you would boost the crankcase... Now if you plug the intake manifold hole, and the rocker cover you are good to go... infact... thats what I do
how fast does your catch can fill with that setup? i've been debating doing the same thing since it would quite literally still leave the crank case under vacuum at all times.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
I use a http://www.saikoumichi.com/ catch can and not much at all.... but its not a daily
