WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Sun Sep 06, 2009 10:39 am
You're adding 20%? If you increase the size of the fuel injector shouldn't you be decreasing the flow 20%?
Look at the narrow band, take away as much fuel as it takes to get the car to run near stoich. Then whatever % you took away for the car to idle, add 15% to that for when the motor is under load.
Retard the base timing some just for safety. If it drives around the block you're ok. Change the oil when you get to where you're going.
WD
