can i drive on 3 brake calipers only???
needwindowmotor
Car: 240sx 95
hey fellas, ive got basically a simple question, i just ordered a new caliper because my left rear one is grinding on my rotor,it sounds horrible and is driving me crazy, and i just ordered calipers form somoene on this site, its just not oging to get here till friday or saturday, in the mean time ive got a date, shopping, things to do......... so my question is, can i remove my brake caliper (its a kinda simple job right?) and just driev around for a few days until i cna have the new caliper professionally put on?
Bwana
Car: Denali
Are you sure the caliper is grinding on the rotor, and not the pads? You can't just remove a caliper, for a couple reasons. First off, it would cause a major brake fluid leak, which would quickly leave you with no brakes at all. Secondly, if you plugged the line off somehow your braking characteristics would be so messed up that it would be entirely unsafe to drive. Hope that helps!
onosqv
Car: '92 240sx Vert
Leave the brake caliper on.
s14_240sx
Car: 96 240sx Zenki
if you want to kill yourself, leave it off.
gabossie
Car: Your mom
You wouldn't want unbalanced braking, so I suggest just removing all four calipers. Make sure to cap the lines Seriously, don't do it.
IDriveFords
Car: 93' Nissan 240sx
Me thinks you need new pads. Calipers don't make grinding sounds unless there are no brake pads. Changing your pads is so simple, even a caveman could do it!
