khisanthax wrote:I guess i'm still trying to understand everything. I have 4 speakers installed (base model) but I can see two speakers on the dash, two in the front door, two in the rear doors and two on the back seat. Am I not seeing a center speaker?
Well, from what I've seen of amps, they are either mono, 2 channels or 4 channels, I take it that a channel is one speaker? I wasn't planning on running components, just regular speakers.
And yes it does have four preouts but I thought it was L/R 2x, i'll check again.
OK, for the non Bose models... you only have 6 speakers...
2 x 3.5" speakers in the dash2 x 6.5" speakers in the front doorno speakers in the rear door2 x 6x9" speakers in the rear deck
now, you have openings in the rear doors for speakers, but there are no speakers actually there! (dumb i know, but that's the way it is)
now, for your front, you don't know it yet, but if you replace your front 3.5" and 6.5" speakers, you need to get a good set of components.. I'm currently running diamond audio s600a components off of ebay for ~ $200 shipped, and I love them. For $200, I would say these are around the best in that price range.. if you want to spend more, I can give you other ideas
but again, just go with components, and use the passice crossovers that come with the components...
and then, you can either get some decent 6x9 speakers for the rear, or it may be better to get another set of 6.5" components, and use an adapter plate to fit them in there.. something like this
http://cgi.ebay.com/ebaymotors...akers
but in any case, for your setup, yu really only need 1 4 channel amplifier... but if you wanted to add more 6.5" speakers to the rear doors, then yeah, 2 x 4channel amplifers would take care of that plus any future plans you may have
in either case, you don't sound like you're very comfortable with car audio, so I would just go to a local shop and talk to them!
