Daledude wrote:Well, I took the MAF out, sprayed a whole can of electrical contact cleaner all over it, and it didn't change anything. The car still starts great first thing in the morning, and takes 2-3 tries to start it sporadically later in the day. It seems to start easier in very cold air (below 35 degrees). Any other ideas? Any recommendations on a MAF to buy to replace it?
Thanks
INMHO I would bite the bullet & let the dealer check it out again to be sure that the replacement MAF is going to fix your problem. Ask to speak to the Service Manager and take care of him or her. Explain that you do not want to end up replacing a bunch of parts. Their OBDll scanner should give them the failure codes to accurately repair your vehicle. Assuming that it is a dirty or defective MAF, how often do you change your air filter?Here is a photo of mine after only 7k miles. You may need to replace your air filter more often?
Telcoman
