can I clean injectors MYSELF
Fenvy
Car: 2005 350Z Base 6MT
i am sure someone is goign to say... take your injectors and get it cleaned...
I was wondering if I can do a half assed job and clean it on my own? like with a brake cleaner or something
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
You need to run pressurized solvent through them while the engine is running. This requires some special equipment that really isn't worth buying, as almost any shop will do it for about $100.
DAEDALUS
I'll do it for the cost of the cleaner (~$15) if you'll take some mileage recordings for me. Shoot me an email if you're interested and if you don't mind driving out near LAX on a weekend. Open offer to any socal folks.
Fenvy
what do you mean? what is involved?
DAEDALUS
Just like 911/Q45 said, it's a solvent in an external container that's run through the fuel rail at a higher pressure than what the rail normally sees. Between the cleaner and the pressure the process attemps to remove any varnish/gunk in the nozzles. The engine runs on the solvent till it's gone.
Fenvy
would you say that they are very dirty? can they be saved? lol
Q451990
The dirt would be internal... Once they're off there's not much you can do to clean them except send them off to have them bench cleaned. I'd put them back in with new o-rings and get a rail flush done as mentioned above.
Heath
Fenvy
which o ring? do I need the big o ring or the small o ring?
911/Q45
1996 Porsche Turbo
Both, not a bad idea to replace the donut it fits into on the lower plenum runners too.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Daedalus.. If I sent you my fuel injectors (w or w/o rail, whichever), could you do the rail flush on them??
Fenvy
i asked him already and he said no
Q451990
You'd have to have some sort of harness rigged up with 12V pulses to open and close the injectors... that's why it's so much easier with the rail on the car. Everything you need is there - just substitute the fuel source.
Heath
QE86
Sorry noob question, how often should you clean the injectors??
Thanks
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
you should never have to if you run good gas and use Techron evey 6-12 months. Modern fuels that advertise 'clean-up' performance really do keep them clean.
Chally
Car: '94 Infiniti Q45
2002 Nissan Patrol 4.8L
2013 Citroen C4 (economy)
Seeing you have removed your injectors, take them to a workshop that specialises in cleaning injectors & make sure they use a Sonic type of Machine as this system will clean as it pulses the injector.It will take a good 1/2 - 1 hour to do them properly & cost about $10-20 each.Don't mess around trying yourself. I repair cars for a living & I send them to the Professionals, as I don't have a cleaner.
Animatorfor3D
Car: 1995 Infiniti Q45
Im moving to mojave after october. I would like to try flushing my injectors. Let me know when your avaiable.
Thanks,
Carl
alamda
Hello I'm a new member and since it sounds like you are the experts on Q's. What is the crankshaft position sensor. I have a 1990 Q45. It started to jerk and cut off when I stop. So I'm having problems if it's the fuel pump (5mos old) or a sensor. It's not turning over and I'm smelling gas. Someone told me the timing chain. I need help.
DAEDALUS
Something I posted 2 days ago:
The engine isn't turning over, meaning the crank isn't spinning at all, or it's just not firing?
