Can i cap this off?
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
I was told that i needed to run a hose from the pipe that is circled red to the intercooler pipe right before the intake.Is that true? I was just wondering if i could cap it off if it is true. Reason being is i for one can weld aluminum and i cant seem to be able to find anyone that can weld a nipple on my intercooler pipe so i could hook a hose to it. If i can that would be great!!! thanks in advance for the answers guys.
R32ONP
Car: R32 Skyline GTS-T
RB20DET
u dont "need" to have it hooked up..mine is disconected and all blocked off..u just have to adjust the idle via the throttle body instead of on the idle controller
Carl H
car may idle like crap depending on your setup...best to have a nipple welded onto the ic piping and route as intended.
R32ONP
RB20DET
if u take both idle controllers off it idles fine if u adjst idle speed on throttle body..u just loose the whole purpose of the iacv (idle air control valve wich is what make the cold idle / auto choke work if u call it that) and u loose the function of the aac valve (auxillary air valve which ups the idle speed wen u use lights,fan,a/c etc etc)...
leesredgt
Sweet. My set up is stock everything except for the BOV and intake ofcourse. Everything else is factory.
