fairladyzz wrote:How much do you about cars and who the heck tell you, you could burn bushings off?? You have to press it put because it's a actually metal with the rubber bushings inside, when you press it out with a press machine! You have to press the new one back in. You need to go to a shop to use a press.
Dude im just trying to get some help. Anyways, if I read what fairladyzz wrote correctly, you have to press because the outer sleeve of the bushing needs to come out also.
So to compare and make sure, you could burn out the FLCA bushing because they wanted the bushing sleeve left in. You have to press these out, cuz the sleeve needs to come out.
