Can I add a amp to the bose ?
handyman64
Car: 02 Path
I have an 02 path with the bose, I was wondering if there is a way that I can add an amp so I can run a sub.. I have done this before with a converter that went from speaker wire to rca, will this work with all the bose stuff ? Also, where is a good place to tap into it ? Is it going to sound good ?
Thanks.
Axelpkt
Car: 2002 Nissan Pathfinder 5spd
Yeah you can, just use a line output converter and tap into the speaker wire right before the the rear amp. That exactly what I'm doing when I finish making my box, hopefully by the end of the week.
fueler
Car: 2 Nissan's
2 BMW's
yup basically use the speaker inputs on the amp with a line out converter... ive done it..... i had this type of setup for about a year and decided it wasn't loud enough, so I ripped out the whole bose and replaced everything
handyman64
Car: 02 Path
Ok, I will try this.. One more thing.. I have not looked for the amp yet, Where is it and how do i know what wires to tap into ? Is it just speaker wires going into the amp ?
Thanks.
