can hla's go bad?
Grambos13
Can hydrolic lash adjusters end up going bad and not able to bleed any more?
fullthrtl_tech
Car: 93 240sx
yes, they can stay overpumped and not bleed down or not be able to pump up at all
Grambos13
How do you know if they are bad? Will it make a knocking sound? And can you tell with a visual inspection?
SpeedRacer1
Car: 1990 240SX, G35
You cant tell visually. If you remove the camshafts, push down on the rocker arm above the hla. If they go down they need to be re-bleed or replaced. If they do not move they should be fine.
ILikeMy240sx
Car: SR Power
Yes, they can go bad.. I had a HLA that even when I bled it before my head went on, after few starts, it was all spongy again.
Like speedracer said, only way to tell is move the cams and push on the HLA with your thumb and see if it squishes.
Grambos13
cool cool...thanks unfortunatly I found out today that the bad sound is not my hla's. It seems to be something in the bottom end...wich sucks because I just rebuilt it. I think its time to part with my ***** and by that I mean part out. Anyone want a gt28rs with less than 100 miles on it?
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
"Want" and "Can Afford" are 2 different things If you do part out, what else do you have?
ILikeMy240sx
Car: SR Power
That sucks man... I know how that feels.... as I just went through my 2nd rebuilds + 2 heads all within less than 2500 miles.
Yeah at first I also confused my rod knock with valve train noise.
Good luck and how much for your GT28RS?
Grambos13
I'm trying to get 800 shipped for the turbo I also have a bunch of other stuff to support it.
ILikeMy240sx
Car: SR Power
Any pics of the turbo? if so, please email to [email protected]
Im interested in the turbo.
Thanks!
