Woody64 »
https://forums.nicoclub.com/woody64-u99751.html
Fri Sep 12, 2008 2:44 am
When I had mine put on, because my car was already at the bodyshop I had him do it because I figured he would have expertise in making them fit right, and he did... I had them off to change a bulb, but they fit perfectly, not moisture or leaking at all.
This is what he did, the bulb is supposed to fit a (3-prong) housing, two of the tabs will line up with the 4 prong on the altezzas, simply trim one of the other tabs to make the third fit in. They fit so tight and will still twist in to lock. If I have time I will try and pull it off and post a picture...
As far as how they look if you like them then who cares, it is YOUR car. I will take all the criticism in the world if I am happy with them. And was even pleasantly suprised that quite a few people said they liked them. Good luck, PM me if you have any specific questions.
