ss1 »
https://forums.nicoclub.com/ss1-u257224.html
Tue Jan 12, 2016 10:04 am
Hi,
I am curious to know if trying to clean an intermittently working alternator after oil leak is a good fix/idea. Anyone else tried it?
Here is the history. I noticed a small oil leak/seep around power Steering pump and took the car to mechanic who suggested changing PS pump. After he changed it, the leak became much worse, I noticed table spoon of oil on the floor after a couple of days of parking.
After the PS pump change, alternator also stopped charging intermittently (Battery, brake and A/T Temp oil indicators came on.)
He then changed Suction Hose assembly and claims the oil leak is fixed and recommended I drive the car to burn off the oil which had come on alternator.
I drove the car a bit and noticed no charging but thought will try shop's recommendation just in case alternator comes back but car pretty much died on me. Called AAA to jump start and fortunately, alternator was working again and I drove straight to mechanic.
Tried again at the shop and alternator was not working(battery etc indicators on). Shop thinks I should change alternator.
I am not sure if I should be trusting them anymore.
Anyone has any suggestions/experience with this? Thanks...
