Ahhhh finally I get to unveil my ghettotastic idea.TurboKA37 wrote:remember that the DSM pistons have a much lower CR than the KA and alot of the reason that stock KA pistons tend to fail under moderate boost is because their design around the rings. the same thing that destroys cast pistons will destroy forged pistons (poor tuning). it just might take longer for the forged to fail. is it possible to run cast pistons with higher boost on the KA? sure, if you can find a set that has lower compression and is designed better than the stock ones. but finding those pistons will be the hard part.
yeah and at a 7.something:1 compression ratio, even miss daisy would be telling you to hurry up.Nismo_Freak wrote:Put KA24DE pistons into a KA24E... voila instant low compression.
9.1:1 early 89. 8.6:1 late 89 thru 90.TurboKA37 wrote:what is the stock CR for the KAE? 8.5 or 9:1 i think?
hahahahahaha. If you are going for a low budget build-up, just replace pistons. They take most of the abuse, so its the last place you want to skimp.demcj wrote:yeah and at a 7.something:1 compression ratio, even miss daisy would be telling you to hurry up.
-demetrius
You getting elitist on me chump? I thought you KA-T kiddies loved the ghettorigging hahah.WDRacing wrote:Yeah but the pistons still suck Alan. The first ring land is made out of chocolate cookie dough...lol.
It'd still be faster than a 9.5:1 motor.demcj wrote:yeah and at a 7.something:1 compression ratio, even miss daisy would be telling you to hurry up.
-demetrius
My bet is on ... 30 seconds.sil80drifter wrote:or you can have the stock pistons/rods/bearings/rings cryo treated for like 15 bucks/set. that'll def. make them last longer. that's what i'm gonna do, and find out just how much longer.
sil80
I couldn't agree more...KATwo40 wrote:lol.
Dude, you're putting too much worry into this internals deal. If you're shooting for around 325whp, just use the stock internals. It will hold up just fine. There's no such thing as a "low cost buildup." It's either "a build up" or it's "stock." Either do the buildup all the way (like to the tune of around 2k$ or just use the stockers.
Honestly, you would be better off just getting a set of forged pistons. The process of forging far outweighs any cryo treatments benefit. Plus this allows you to run a freshly machined bore.sil80drifter wrote:Then you are well on your way. For a basic understanding/reinforcement of knowledge about engine components and mechanics/basic fuel delivery I would start with http://www.howstufworks.comThen just start googling up stuff like "basics of engine fuel delivery" or "engine tuning explained" or "car tuning"I've come up with stuff like
http://www.tuninglinx.com/html/articles.html
from the above searches, and I'm sure there are better phrases to look for.
And of course, this board is an excellent source for research as well, but don't limit your self to any one board, because nobody has everything, although this board is among the best out there.
Set some goals like "today/this week I wanna know about ignition/fuel delivery/suspension/etc" and just go at your own pace.
good luck.
Nismo Freak: no faith in cryo?
sil80
