can bose mess up aftermarket radio?
Post all your Nissan electronics, car audio and stereo questions here!
omarb45
Car: 1994 q45 t/c black on black
have a pioneer dvd in dash worked ok with bose as long as bass was down.had to work on car reconected battery n radio was on full bass blast then turned offnever to come on again..any help?its a double din slot loading player.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Probably not, but double check both of the fuses to make sure that you didn't blow any of them. Did you have it connected through a line level adapter, or just straight to the bose system?
omarb45
I didnt do it,installer where I brought it did it.Probably straight hook up.At least he did a toggle switch on console to watch tv.iI checked fuse under dash it was ok,so pull out radio n check that 1?
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
There's one under the hood. I'm not positive if there is a separate one for the bose amp or not.
zerepdivad
Car: '90 240sx . '02 Lexus IS300
If you went to a shop and the installer bypassed your in dash then that doesn't speak too highly of that installer in my opinion.
omarb45
didnt understand your post,anyway it was a place called audio works in Texas.My amps were already dead so theybeen takin off.removed factory tape deck n put in duoble din dvd worked good as long as bass wasnt set to high guess factory speakers cant handle it. too much distortion.had a sony worked good but later went with now the non working pioneer.so.. can the speakers send some kinda signal or something back to reciever messing it up?
zerepdivad
What kind of car was it? Do you know the impedance of the speakers? Many bose systems are 2 or even sometimes 2 ohm speakers. ANd if the bose amps were bypassed and those said 2 or 1 ohm speakers were hooked up to the deck, they could very well damage the deck.
omarb45
Its a q45.changed out door speakers for 6'5s but kept factory 6x9's
