Can AWD be shut off? Plus a couple other questions.....
A forum for lovers of Infiniti's hot-rod crossover, the FX! In 2014, all FX models will be named Infiniti QX70, in line with Infiniti's new naming structure.
mikeydiker
Looking into purchasing fx35. The switch on the left of the steering column that reads AWD Off/ON?
Im looking at an 04. With Tech/sport hoepfully.
I want NAV/DVD/Xenon lights/back up camera/Moon Roof/20s
Are those options seperate, or part of a package?
Thanks
PS anything to look for in this year?
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
mikeydiker wrote:Looking into purchasing fx35. The switch on the left of the steering column that reads AWD Off/ON?
Thanks
Welcome to NICOclub fellow Wisconsinite! Glad to have you here! Sorry no one greeted you sooner. Technically we do not have an FX Forum Mod, but I can assure you we are thrilled to have you as a member here in the FX forum.
I wish I had more answers to your questions, but as far as the AWD switch is concerned, I DO NOT believe you can turn it off. If you turn it on, it LOCKS the AWD so that is on permantly on speeds of 25mph or slower. I can offer you this, check out the 2004 FX owner's manual here:
http://x.infinitihelp.com/forum/local_l ... p?catid=55
White_Hair
Car: 03 FX35 AWD - Touring Package
AWD will be switched to RWD when your speed is below 40km/h without switching on the AWD switch.
If you want to make sure it is off. Keep your car running fast.
Return to “Infiniti FX35 / FX45 / FX37 / FX50 / QX70 Forum”
