asoomal »
https://forums.nicoclub.com/asoomal-u90618.html
Mon Nov 11, 2013 6:09 pm
Measure the length of tension control rods on each side and check if there is a difference? Measure from the center of the front bolt that is connected to the bracket to the middle of the two bolts where it mounts on the LCA.
If there isn't, the bracket for the tension control rod is bent and/or broken.
If there is a difference, the rod or the bushings will need to be replaced.
Also take off both LCA's and compare them...
