IBCoupe »
https://forums.nicoclub.com/ibcoupe-u134097.html
Tue Mar 15, 2011 3:29 pm
Does the noise only appear when you turn the wheel a certain way - maybe only left or only right? Does it show up above certain speeds? Is it accompanied by a vibration in your steering wheel, gas/brake pedals, shifter (either CVT or stick)?
Might be a bad wheel bearing. Take it to a shop if you're not confident in the diagnosis, and have them find it. Warning though: they might tell you that it's nothing at first, because you're more attuned to the noises in your car.
I've gone through two of those. One at about 36k (front driver), and another at 78k (passenger). If you're not going to do it yourself, it's going to cost you probably between $300-500, depending on where you go. If you do it yourself, you'll need a wheel puller, and you'll need a new wheel hub assembly - about $125. Be careful to buy the correct part.
