Can anyone tell me were my sr came from?
Sleeper_RMS13
Car: 91 FB W/Blacktop SR
I was woundering if anybody could help me find out what kind of 180sx my blacktop sr is from?It has the hicus steering pump if that helps any? When i got the swap it didnt come with the plate with the vin # and all the other info it has on it. And i dnt remember what ecu i have now. Thanks.
saywuh
Car: 95 Nissan S14.5 240sx
well your sr blacktop having wc or 62 ecu then we might KNOW...and coming with hicus steering wheel pump is from SPECIAL SE HATCHBACK i think..i hope that help..im not really knowing s13 im all about s14
Sleeper_RMS13
Well anything helps i guess.I was searching for chassis code and i guess it would be under the kps13 casue it was a hicus.I just really want to know if its from a type x or not.I figured since the transmission had a pretty beefy clutch in it and the cold pipe for th smic is not plastic and is bigger than the oem coldpipe and also the turbo manifold had been removed more than once that the guy who owned his 180 was somewhat of a racer haha.
MrSoutherland
Car: S13 - Sr20
The type-x uses a J4 ecu. Are you having problems with the motor or just wanting to know where it came from?
Sleeper_RMS13
No problems at aqll i just wanted to know.And when i get back to my car ill check the ecu.
