can anyone show me a pic of a stock sr20det maf sensor?
shedrifts
Car: rb powered sil80
like the topic says i need to see what a stock maf sensor looks like off a sr20det because i think mine is wrong thanks
kane2g
Car: 92 240sx 95 240sx
SpeedRacer1
Car: 1990 240SX, G35
Check to see if the part number matches, if it doesnt post up the part number you have.
rudee023
Car: '03 Infiniti Q45
Part # F00 is a SOHC MAF. It's interchangeable with the SR MAF but is not a true SR MAF if you are anal about it.
SpeedRacer1
rudee023 wrote:Part # F00 is a SOHC MAF. It's interchangeable with the SR MAF but is not a true SR MAF if you are anal about it.
F00 isnt the significant part of the part number. This part of the number will not tell you anything terribly significant about the part. Nissan numbers read like this:Sample (NISSAN S14 MAFS): 22680-69F0022680 = This tells you what the part is, ALL Nissan MAFS will start off with this number.69F = This is the model/engine, so 69F means S14/S15 SR20DET, 52F means S13 SR20DET, you need to know this part of the number to know what car some part came off of.00 = slight variations in basically the same product. For instance 00 on an S14 MAFS means its from a Zenki S14 (1993-1995), if it says 01 its from a 1995-2002 S14/S15. The only difference is the shape of the connectors.
