Can anyone share the complete fsm for an s13 redtop (91)?
mrzabala
Car: 93 Nissan 240SX SE Hatch
I have the s14 sr fsm. But some of the things on it are different than the s13. Can anyone upload an s13 redtop fsm thats either in japanese or translated. Ive already gone through zeryon and links given in FAQ and no luck. Thanks for the help.
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
http://www.camel-towing.com/
This is also liked through the sr faq sticky thread.
mrzabala
I already been there. I already mentioned that I been to faq for the fsms.... It doesnt have the specific fsm for an s13 sr20det.... Please read before posting something wasteful.
S13240
No known English version of the s13 sr fsm. What you looking to do anyway?
adrianfromthecastle
Car: 1992 Nissan 240sx
S13240 wrote:No known English version of the s13 sr fsm. What you looking to do anyway?
someone frekkin translate one already... ugh! hey zabala... if you ever get lucky with the s13 sr fsm, drop me a line, ive been looking for one too
ILikeMy240sx
Car: SR Power
S13 and S14 are virtually the same. Why would you want a S13 specific one anyways?
All the important torque specs are the same.
mrzabala
It isnt the same. The pin outs for the ecu are different. And the torque specs are not all the same. Instead, some have a difference even its little (If it says 12ft lbs of torque and you can only read off an s14 that tells you 14ft lbs, your more likely to cause problems like cross threading). I just want to have an s13 fsm for my sr instead of worrying about the difference. Lets put it this way, why should I make it more difficult on my self when I have to determine if something is the same when reading off a different fsm. I'll know that I dont have to worry about any of it because its the fsm for it. And another way to put it is, Why make 2 fsms if you say there virtually the same, can't they just put that its from this year to that year to cover the s13 and s14? :
Adrian, Ill upload it when I get it so I can share it. Hopefully someone has it instead of making remarks that are just a waste of time.
adrianfromthecastle
dude... ive been searching forever. i havent even found an s13 sr untranslated besides the motor differences, i would just like to have my motor and chassis all in one fsm (havent even dl'd the s14 sr yet, the site was down).good luck
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
i think part of the problem your possible might have is that whilt the SR (S13 verison) was in its hayday, the FSM was on books not discs. that might be part of the problem..i know at at work the oldest nissan i can look up like a 94 or 95 on ASSIST
mrzabala
I wasnt refering to you when I typed, "Hopefully someone has it instead of making remarks that are just a waste of time." But I have the s14, http://www.camel-towing.com/ I think still has it.
ILikeMy240sx
Car: SR Power
Waste of time?
There are S13 ECU pin outs everywhere and even S13 wiring diagrams everywhere. Just go to the site that you linke and it has all the wiring diagrams you need.
We've all been trying to find one for S13 SR but its not out there. You mentioned that S13 and S14 torque specs are different. Exactly which torque specs are different for S13 and S14 SR20DET?
Ive rebuilt 3 S13 SRs so far and followed the exact torque seq. and specs listed in a S14 FSM. Also followed clearaances listed in a S14 FSM and never had problems so far.
And if you really need the torque spec for every little bolt that's on the block in order to not strip the threads on the block... well.. good luck. Sometimes even when you are tightening to the spec, threads will strip.
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Iv used a s14 FSM on all my s13 rebuild's too,4 of them.And they are the same thing..Why would they have different torque specs..Its the same motor..They were even made at the same time..And 2lbs of torque differents wouldnt matter at all..
In fact i have a few s13 FSM page's,Like the intercooler,turbo and manifold's..With all the torque specs and they are the same as the s14 in every way.
