Can anyone point me in the direction of 5spd swap instructions?
Scooby24
Car: 01 BMW 330CI
I need s14 instructions preferrably with pictures....
Have to figure out how on earth I'm going to wire the transmission....
I've got a 1997 and swapping in a 89-90 transmission...Obviously none of the connections from the 97 Auto work with the manual and I've got no idea what to wire...I suck at electrical stuff.
Scooby24
Car: 01 BMW 330CI
bump...well I found the S14 harness layout diagram....but I need an S13 to see if they use the same connectors...
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
http://www.240sx.org/links/ins...p.htm
The wiring is pretty simple actually. Jumper two wires together, and wire up the reverse lights. You don't need the 4th and 5th gear sensors wired up.
Scooby24
Car: 01 BMW 330CI
Okay...well the speed sensor connector is different so I just gotta cut the old connector and attach it where the new connector is?
Also what function does the o/d sensor serve?
Edit: And does anyone know what the connector that they are referring to as the "third from the top" using pins 3 & 8 is?
