Can anyone identify this hose for me??
yellowtwin
Car: 1991 Nissan 300zx TWIN Turbo
I think it's covered in oil but im not to sure on that, i just want to replace it and hope the problem is fixed. Thanks
Modified by yellowtwin at 1:43 PM 4/5/2010
NolimitZ32
Its the Low side A/C hose, goes from accumulator to compressor, and if its covered in motor oil then you got a leak above that, probably one of the turbo oil feed lines or the oil cooler lines.
yellowtwin
Ok thanks
NolimitZ32
NP man.
KevinZtwin
Car: 1990 300zx Twin Turbo
I would say it is more likely a leak coming from the power steering pump (which is directly above that hose). The oil cooler lines are also right there, but my bet would be ATF from the PS pump or leaky PS lines. What color is the fluid?
yellowtwin
Alright thanks again, it is the power steering hose. I should of known this because I have refilled the fluid twice already. Thanks again
