Can anyone help me open my trunk on a 90 Q?
kevinc
Ive got a 90 Q and cant get into the trunk, Key Wont work, trunk popper on the door doesn't work I don't hear a click or anything, and yes Ive messed with the button in the glove box. I'm guessing the only way in is to take off the rear parcel shelf and go in that way, Ive done that but Can't figure out what I have to push pull or tickle to get the thing to open manually, any Ideas?
96Qowner
Car: 1996 Q45
Heheh, have you tried this?
Re: TRUNK OPENED! WOOHOO! 5:31 AM 1/17/2003
Quote »Originally posted by TgvinceThere is a little switch in the glove box that only allows the key too work...thats not the problem with mine.I did however get in! Pure luck be it good or bad:). I removed the lisence plate hopeing to see what i dont know but in fustration i smacked the area behind the plate...I tried the release on the door a couple times and behold the trunk poped open! WOOHOO! I pulled the cosmetic panel to see what the heck was up...It appears that a stupid little nut had loosened up off of one of the tail lights and found a home in the latch mechanism apparently when i whacked the decklid it jarred it loose...I got ultra lucky, so i thightened all the nuts on the taillights and all were kinda loose by the way....So no holes drilled or knocked out lenses or worse:)...Thanks for all that advised me in this delema!
Terrygoing outside right now and give mine a wack wish me luck...lol
Also, check fuses.
