i apreciate it but this is the problem i keep getting, noone has a sure answer for me, thanks thoDriftBoy07 wrote:I would imagine you could use the S14 lines with the PS pump on the engine, if not then you just need to order an S14 pump. I would think, dont take this as word of god either
i have a s14 resovour with one hose coming off it and the metal lines under the motorsafin wrote: which lines do you have? is really easy to make them work with the sr pump
i actually never had KA, but i had lines in the 240 i had that worked fine with the SR.........
use the search feature...
