dhen »
https://forums.nicoclub.com/dhen-u100551.html
Thu Feb 21, 2013 5:15 pm
I can't check the fluid level in my transmission, which isn't a problem assuming it's not leaking. Anyway, if I have the output shaft seal off, oil comes out. Assuming the car is level, after I replace the seal, how much more oil should I add? I have to add it through the shift hole.
Thanks,
Darian
PS It's the CA 5-speed manual transmission.
