godzilla34 »
https://forums.nicoclub.com/godzilla34-u69864.html
Sat Oct 06, 2007 5:43 am
how long have you run the motor after the install? i know even if you bleed the lifters, it still takes some time to gain oil pressure again, and the tapping could be because of the lifters not having oil, (bleeding helps butit still occurs) it happens after loss of oil presure, new motor or various other things, if its been a while since your install check your oil pressure to make sure your set. good luck
Modified by godzilla34 at 9:09 AM 10/6/2007
