SketchyRollin564 »
https://forums.nicoclub.com/sketchyrollin564-u60600.html
Sat Oct 01, 2011 12:39 am
To make it short, i swapped my blown turbo two nights ago. Putting the new one in, me and my friend were working on different things at once to get things done and put back together quicker. He was the one who put in the banjo bolt for the oil line that goes to the turbo tward the bottom of the block. Im guessing he put it in crooked or something, because when i started the car, it began leaking oil down there. We figured okay, it needs to be tightened more... well when we went about this, it just kept spinning.
Taking the bolt out we found metal strippings from the block! Awesome! With my luck this would happen... and with the actual block and not the bolt (im guessing cause its an aluminum block and the bolts probably tougher). Another friend had a good idea, and we tried removing all the crush washers to see if we could catch deeper threads, and some how, miraculously, this actually worked and it didnt leak.
I cleaned the area with brake parts cleaner to check for leaks. Didnt leak under idle with cold oil (higher oil pressure), and not under mild reving either. With the car and oil all warmed up and not leaking i did a couple of hard pulls to see if it would leak, and when we got back it was still dry
This is good, since it means i can still drive around and get to work, but this also means that that bolt is only held on by like two or three loops of threads. Meaning it can easyly back out, or break the threads at any given moment... i dont need that to happen
Does anyone have any ideas on what i can do? I was thinking possibly i could re thread it, but i dont know if that will actually work on a block. In the mean time ill be checking that banjo bolt every time i get into the car and ill be ordering a cheap prosport oil pressure gauge asap to keep an eye out on it, but i still want to fix this as soon as possible so i can take my car to the next drift event and not have to worry about this. And so i can drive period without this risk.
any help/ideas/suggestions GREATLY appreciated!
Cliff Notes: Swapped turbo, friend put in banjo bolt for oil line and somehow stripped threads on block. Leaked oil, removed crush washers, now doesnt leak. Problem: Bolt only held on by 2 or 3 loops of threads. Huge risk to drive like this. Solution? no fcking clue... wanna help?
SketchyRollin564 on Sat Oct 01, 2011 1:03 am, edited 1 time in total.
