KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sun Dec 31, 2006 4:08 am
Using two wastegates is not a good idea. The only thing you're going to accomplish is choking the exhaust flow behind the turbine, because the add-a-gate flapper assembly that goes on the back of a 5-bolt style turbine housing has a smaller exit than just the turbine exit itself. So, in using this device, you're going to be forcing both the turbine gases and the waste gases through a hole about 2". Yay.
Additionally, this will cause exhaust manifold pressure to rise, and spool will be slower, since the delta P across the turbine wheel is going to be lower.
Use the external 38mm gate, get a $10 5-bolt flange that covers the wastegate hole in the turbine housing and make a nice downpipe.
Using two wastegates will also result in both gates shuddering, rather than having smooth operation.
