float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sat Nov 24, 2007 7:13 am
No, the CA MAFS. You can use ANY MAFS you want, but if you don't burn the ecu for it, it isn't going to run well.
I would guess that the KA E is the least far off, but I'm not sure.
You would AT LEAST need a SAFC to compensate for how lean the car is going to run if you aren't running the right MAFS.
