Bluefire »
https://forums.nicoclub.com/bluefire-u7784.html
Thu Feb 14, 2008 6:01 pm
You can run s2 coilpacks on an s1 harness. You just eliminate the igniter and connect the wires direct. Also s2 and s1 coilpacks have opposite mounting points, so if you swap them make sure you get the aluminum brackets as well. Otherwise you have to tap the brackets for the new coilpacks.
Also about the cas being different, this is a very, very rare case for R33 RB25det's. Only a very few came with the black covered cas. When buying cams, early model relates to motors with aluminum cas, and late model relates to motors with the black plastic cas.
As posted above tps' are different between s1 and s2. If you swap the throttle body also, you just need to wire in new plugs and your good to go.
As for ecu's, I can only verify that S2 ecus and power fc work on both series harnesses. I have yet to try and S1 ecu on a S2 harness.
-Bluefire
