i have a 92 sentra e and im planning on doing either a sr20de or det swap i found a nx2000 and the junk yard and started ripping things off immediately but someone already took the ecu and i was wondering if even though it was a automatic sr20de is it like a 240sx were you can still use the engine harness?? because i left it because i wasnt sure it would work......i know alot about 240sx's but im new to sentras so your help is much appreciated thanks....
again the question is will a automatic nx2000 sr20de harness work in a 92 sentra E chassis if so is it plug and play or will something have to be moded???
