Can a NA transmission be used for a TT engine?
StatixNWH
Hey guys i was just wondering if you can use a NA transmission on a TT engine, ive just heard both ways so seein if you guys could tell me, thanks.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the transmission should swap over just fine, I think the issue is wether the N/A transmission will hold up to the abuse, a VG30DE block and a VG30DETT are built on the same block casting
StatixNWH
are the trannys any diff between a NA and TT car?
cville300zx
Car: 1990 300zx 1993 240sx
The trannys have the same identical internals. The N/A transmission will work. go to http://www.ashspecz.com and read up on his n/a to tt conversion it will tell you all the info you need to know and answer all of your questions.
boileralum00
Car: 94 Miata, 95 FZR600R
You can run into difficulties w/ the flywheels and starters though. There has been a lot of discussion about it on tt.net, but I don't remember what the definitive answer was. If you get it on and it doesn't want to start, you might need to shim your starter out or swap it for the other one.
greatgonzer
Car: 1990 Nissan 300ZX NA to TT conversion
The NA transmission will NOT outright work on a TT engine. The TT flywheel IS bigger and the bellhousing is milled out more. You will have to get a dremel and grind out the bellhousing slightly. Also you will have to shim out the starter so that it will engage the larger diameter flywheel...Then it will work...
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
or you use an NA flywheel.
cville300zx
The internals of the TT and N/A trannys are identical. Now like stated above you will need to use either a TT clutch and flywheel which I would suggest then you grind down inside of the bellhousing a little and shim out the starter or you can use a N/A clutch and flywheel and everything should work out perfect but the TT clutch and flywheel will be stronger.
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Why not just save yourself the trouble and bolt on a TT transmission? They sell at salvage yards and on part outs for the same prices as NA ones with the bonus of not having to modify it.
