Fahaka »
https://forums.nicoclub.com/fahaka-u3472.html
Mon Jul 31, 2006 5:18 pm
yes, it will fit. You need to swap oil pans, oil pickup, oil filter mount, engine mount brackets, and the dipstick hole is in the wrong place, so drill a new one and plug the old...plus you will only have half of the transmission mouting bolts because the truck block is lacking the skirt of the japanese motor. Also the starter is different, you will need to use the truck starter and harness pigtail...
