if your
24j0hn wrote:as some of you have read from a previous thread, i have been having an over heating problem...
i have fixed/ replaced :Radiator Fan clutch Nissan thermostat Headgasket Bled and flushed coolant
my problems when i drive the car will be fine for about 10 minutes then it overheats... so i pull over and turn it off... no longer than 2 minutes later i turn on the car and and the temp rads normal on the third needle... so this will happen about 4 times on the way to school... but on the way back it happens once... but when i pop the hood this burst of hot air smothers me and the valve cover is hott...
what im going to do tomorrow im going to the junk yard and picking up a radiator fan(dont have one, but do have a cooling fan) and will try to find a good catalytic converter in good shape and see how that works and upgrade to a high later
Do you think itll work cuz ive tried everything and this seems like a plausibe solution
if your current cat is cloged it would cause poor power and sluggish preformance im pretty sure it wouldent cause you car to over heat.
the cooling fan is not a replacement for the main clutch fan.either get eletric fans for your radiator or put the clutch fan back on with its shroud.
then like the last guy said it could be air in your in your coolant lines or a crappy head gasket.
AND if its not a head gasket and you keep driving it till it over heats it prolly will be a head gasket very soon.
