martins_240sx »
https://forums.nicoclub.com/martins-240sx-u49295.html
Thu Dec 31, 2009 6:58 pm
Okay erase what i said about it not fitting....well in your setup as of now it wont work...the stock flywheel friction surface is 225mm that clutch is made for a 240mm friction surface. in order for you to get your setup to work you need to get a flywheel from a 1986-1994 nissan truck 4 cylinder (d21) that will bolt up to your crank although there is a little stud that sticks off of the crank...hit it with a hammer to break it off. no worries its not needed. now bolt it up. If you got a flywheel with nine holes then either get 3 more bolts or dont use the middle of the 3 sets of 3. you CAN according to this information i found from searching white bunny special use that clutch and flywheel setup, but you will need a d21 flywheel...its like 80 bucks. you will have to grind your metal dust sheild due to the different contour of the back of the flywheel. or just bolt it together and let it grind itself down...very loud but wont hurt anything. then enjoy great clutch setup You should search for "white bunny special" you'll notice that im asking in or starting most of the threads.
heres the compatability list I stole from someone else in a previous white bunny thread
280ZX 78-83 2+2 non-turbo280ZX 1979 2+2 turbo300ZX 84-1/31/89 non-turboPathfinder 86-89 2.4Pickups 2.0 83-89, 2.4 83-12/31/96
Years Make Model Engine Type Liter Size 1987 - 1988 Nissan 200SX V6 3.0000 1975 - 1978 Nissan 280Z 2+2 L6 2.8000 1978 Nissan 280ZX 2+2 L6 2.8000 1980 Nissan 280ZX 2+2 L6 2.8000 1982 - 1983 Nissan 280ZX 2+2 L6 2.8000 1981 Nissan 280ZX 2+2 GL L6 2.8000 1984 - 1989 Nissan 300ZX V6 3.0000 1984 - 1989 Nissan 300ZX 2+2 V6 3.0000 1983 - 1985 Nissan 720 Pickup L4 2.0000 1983 - 1985 Nissan 720 Pickup L4 2.4000 1986 Nissan 720 Pickup L4 2.4000 1986 Nissan D21 Pickup V6 3.0000 1986 - 1994 Nissan D21 Pickup L4 2.4000 1987 - 1989 Nissan Pathfinder L4 2.4000 1994 Nissan Pickup L4 2.4000 1996 Nissan Pickup SE L4 2.4000 1995 Nissan Pickup Short Bed E L4 2.4000 1994 - 1996 Nissan Pickup Short Bed XE L4 2.4000 1994 - 1996 Nissan Pickup XE L4 2.4000
