DCIracer wrote:Actually, the hydraulic lifters on the 25 head are ideal with most people that tune these engines in Japan and Australia. The VVTC is also a nice feature of the RB25 head.
The RB25 head has the capacity to flow more air based on the runner size of the manifold. If you have ever taken the two engines apart side by side, you would know this. The RB25 has a heart shaped open runner and opening on the head, the RB26 has a smaller, round port on the manifold and the head. The larger a hole, the more air you can get through it.
The lifter is the almost exactly like the SR20 hydraulic lifter, which has proven time after time to die. It's the same for the VG30. If the hydraulic lifters were superior to the mechanical ones then why do they offer a mechanical conversion kit.
If your basing headflow solely on the manifold and the size of the intake port opening then you are making a mistake. Headflow is determined by the amount of air that can flow THROUGH the head, not into it. I could make a head with a 4" opening but with .2" valves that would flow asbsolutely nothing compaired to an engine with a 2" opening and valves twice the size. Flow is not based on size nor is it based on the look of the head (IE. Polished everything). The RB26 head may feature a smaller intake port opening but this helps to maintain velocity in the head. The only true way to determine head flow is to flow bench the two at the same vacuum.
The manifold on the RB25 is an equal length runner design. This is ideal for providing equal dispersion of intake air to the cylinders, but it also becomes a restriction in it's own right due to it's longer curved intake runners. The runner design is there to produce midrange intake air velocity into the cylinders to improve bottom end filling of the cylinder. This is why the RB25 has better low end and midrange response than the RB26. The RB26 on the other hand has a typical blow through manifold design with 3 dual throttle body setups and short runners. The manifold was designed to do one thing, flow at high rpms.
If it were true that the hydraulic lifters and RB25 head did flow better and operated better don't you think we would see the widespread modification of the RB26 head to accomodate this? Instead we see the opposite.
Talk to Mario at Ex Vi Termini, try to tell him to keep the hydraulics in an SR20 or RB25 head.
Or, you can call JUN and ask why they are using RB26 lifters in their 2JZGTE builds.
Tomei has a solid lifter conversion on their higher stage pre-built motors.
There are 3 very very reputable engine builders from down under and mainland Japan that found the need to change over.
