placham »
https://forums.nicoclub.com/placham-u38577.html
Fri Sep 29, 2006 2:13 pm
I have checked the FSM, and I can only see one problem here. Assuming that all the parts are good and working properly, electrical has to be fine aswell. Did you do a motor swap? I undertand that you said you have a 95 KA24DE in a 93 right. Assuming all the parts that you use from the 93 like wires, dist, and ECM are working properly. Do one thing make sure you have good chassis ground. When I helped my bro put a KLZE into his MX-3. The engine cranked fine, had fuel, and ignition, but it did not want to start, if it did it would die right away. We were chnaging out his J-spec Intake manifold for US-spec K8 manifold, but we forgot to connect a body ground or chassis ground negative/ground wire to his intake manifold. Once we figured it out the car started and ran fine. This might be something or it could be nothing be worth a try. Looks like the ignition system is based on chassis ground from looking into FSM wiring diagrams. Bad chassis ground is a common problem on cars of all makes. You could use a test light to verify ground or power source for ignition components conectors, and use DVOM/ multimeter to verify good components.
I have a KA24E, if it's the same as KA24DE you should have external ignition coil. Pull of the wire that connects coil to distributor, when one end pluged in to coil hold the other end over metal part of the body(where ever ground is present). Have someone crank the the engine for you, check to see if you have spark coming out of the coil (MAKE SURE YOU DISABLE THE FUEL PUMP, SO YOU DONT FOUL OUT THE PLUGS) If you have spark coming out of the coil than you know that your electrical part of the ignition system is working properly. So if your car does not start, and you have spark at the coil than it could be 1. distributor not timed correctly with engine2. distributor rotor not installed correctly(if it's possible), or bad rotor3. bad distributor cap4. bad or fould out plugs (plug gap would be something to check aswell)5. bad plug wires, or plug wires not on the correct number cylinder plug. dist cap should have the numbers on it (not sure which way rotor turns CCW or CW, reading the numbers in that order should tell you the firing order, its either 1,3,2,4 or 1,3,4,2.Easiest way to verify all these (except the plug wire order) is to take out the plugs and conect the plug wires to them, and verify that each wire and plug are putting out a spark.
Now if you dont have a spark eather at the coil or the plugs, than you have an electrical problem. which would be hard to explain, this is where the Factory Service Manual is "worth all the big bucks that it costs" comes in handy. I also had no spark in my car when I first got it, I replaced the complete distributor the power transistor the coil and the resistor(everything costed me about 80 bucks from salvageyard) , but at that time I did not have the FSM, that was one of the reasons I got one now.
Anyway I had no ground going to the power transistor, that was why I had no spark, it was electrical fault.
TO R&R (remove and replace) distributor or Time the distributor, steps are1. engine must be at TDC compression stroke. I have a compression gauge at home, so this is easier for me. Because I use the piece that screws into the cylinder head and hold my thumb over the other end and that way I feel when its Cylinder number 1. at compression stroke. Than I turn it back the other way just a little bit, stop, and turn it back the way I was turning it first to align the TDC marks. Or have someone help you to turn the engine, and the other person(on DOHC hold your hand over the cylinder No1. spark plug boot hole so your making a seal of sort with your hand and feel for compression if you feel compression, tell the other person to stop turning the engine over. Back it up a little bit past TDC marks, stop and turn it back the way you were turning it before align the TDC marks. On SOHC the idea is the same but you hold your thumb over the spark plug hole on cylinder no.1."I have not tried this but I think if you hold the throttle body "butterfly" flap wide open you should feel a lot more compression, because when doing an actual compression reading that is on of the things you have to do WOT throttle"2. remove distributor3. replace distributor with rotor pointing the right direction. This is the step in which its really got to know which way the rotor is turning I think its CW. But to verify before removal of dist, remove the cap have some one crank, or turn the engine over a couple of times, note the rotation of distributor. THE IDEA HERE IS TO SET THE ROTOR JUST A LITTLE BIT BEFORE CYLINDER NO.1 DISTRIBUTOR CAP "PRONG" OR "PLUG TOWER" their inside the dist cap four of them with "carbon button" in the center of dist cap that make the connection between cap and rotor. It's really good to verify that before tightening the dist bolts, hold the dist cap over the dist and the rotorassembly, it should be just a little bit before number one cap tower. when looking at disatributor when engine on cylinder number 1 TDC the rotor tip should be facing downwards to the right(on KA24E)4. reasamble dist bolts, dist cap, and the plug wires.
That is how I do it and have done it in the past.Sorry if I have wrote a lot, just want to help out, to time the distributor its much easier done than said (onec you have done it before or have seen it done).If everything worked fine before than I bet its the plug wires that are mixed up or you have bad conection at conectors.PEACE
P.S. I'm not a 240sx wizz in any way, but there might be some differences in the distributors for KA24DE, your old one could have shorter shaft or something, make sure that the rotor actualy spins, or that the shaft is actualy making contact with the (oil pump I think) gear. Or there might be some differences between the older an newer ka24de's electrical dont know I'm just spit-balling here.
By the way code 11=Crank angle sensor circuit code 21=Ignition signal missing in primary coilthose are for Ka24e out of '90 240sx FSM
If you have access to FSM for code 11 section "EF&EC-86" it looks like there is one or two fuses or fusable links in relay box, ECCS relay, crank angle sensor the wiring, and there is also a chassis ground, or body ground it would be wire color "B" at crank angle sensor conector, which is ground that would be something to check BAD OR WEAK GROUND IS A COMMON PROBLEM ON ALL MAKE OF CARS CHECK THAT. Code 21= section "EF&EC-94" FSM. A lot of components to check and wires, and conectors as wel to verify but check to see if you have good ground to resistor an condenser wire color"B" which would again be chassis ground, and power transistor wire color "B" chassis ground.
Modified by placham at 5:25 PM 9/29/2006
Modified by placham at 5:48 PM 9/29/2006
Modified by placham at 5:56 PM 9/29/2006
