Can 1991 Q45 rotors/calipers/rims be installed on an S13?
SFBayQ45
Car: cars
Go a set of rotors and wheels that I can install on the S13. Would it fit in terms of offset and everything?
max240se
Car: 95 240sx
prolly not, but you could try since you have them.
S13 is 4-lug, Q45 is 5.
However, once you do the 5-lug conversion (big job) you can run Q calipers and rotors.
Fenvy
Car: 2005 350Z Base 6MT
in addition to that, you can redrill the rotors to 4 lugs and it will fit fine
here is a old photo of 4 lug s13 with q45 brakes (redrilled rotors) on 18s"
