camt figure out whats wrong with my 240!!!!
Madeintheshade90
Car: 1991 nissan 240sx super hicas
I bought a 92 240sx coupe with a blown motor. i swaped a ka from a 96 240 into it. at first when the car was taken over 2000 rpms it would start cutting out. i changed the fuel filter and started putting 93 octane gas in it. it ran alot better but the acceleration is still horrible and it still cuts out ocassionally. i bought fuel injector cleaner and that didnt help. i dont know what to do to it. anyone have any ideas?
Modified by Madeintheshade90 at 8:09 AM 4/1/2007
jackasspyro1993
96 motor is ob2 and a 92 240 is obd1 so u have to convert the motor to a ob1.and if thats not it also sound like u might need to get a new maf or its unpluged
Madeintheshade90
yea i when i did the swap i bought a new distributor for the 92 ka and put that on the new motor. but i will check out the maf
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Did you use the '92 intake system and exhaust system on the '96 motor? If not, then that is most likely the problem.
Madeintheshade90
i used the 92 exhaust. i was told that the intake was the same on both motors but im not entirely sure.
jackasspyro1993
na i u need to swap intakes also. i forgot wat it is but they have some dum little difference that will mess everything up
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
Madeintheshade90 wrote:i used the 92 exhaust. i was told that the intake was the same on both motors but im not entirely sure.
I believe there's a difference in the TPS between the two.
coupe240sxguy
Car: '89 240sx/ '01 mazda 626
some kind of idle air sensor- map sensor, tps sensor, maf sensor, idle air screw loose (in the intake manifold), just to name a few.
dgms240
Car: '90 s13 hatch ka24det
u need to use the 92 intake manifold, or at least the top half with all the obd1 stuff on it. i even had to do this when i put a 96 motor in my 95!
