camshaft turning how-to?
Killahsmurf
Car: 1990 240sx
car: 1990 240sx (ka24e)
so, some months ago i found out that my cylinder head was completely ephed. warpage, valves burnt (even intakes), etc. i finally got around to getting a new complete head from Clearwater CylinderHead Inc (so far, their service was great). the only thing is when they put together the head, the camshaft 90 degrees after tdc. i need a a way to turn the camshaft (without buyin the 'special tool' thats effective an wont break anything. any suggestions im open to. but i gotta get this done like quick-fast :P
gumby74
I am confused, is the head installed on the motor? If not simply turn the cam gear bolt.If it is installed, things get fun. You can either jump the chain a couple of links at a time, or remove the chain from the cam gear and turn the cam via the cam bolt.
Killahsmurf
Car: 1990 240sx
haha, im an idiot sometimes... first of all, its off, and i had already turned it with the cam bolt. then i read your post :P thanks anyway
H8tred
Just so you know in the future, you can use an old timing chain to make a chain whip just for such things.
