Camshaft Timing "Q" ('91 Q45)
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
Raxephon
Car: '04 RX8...for the moment...
How many chain link pins, counting each pin between the 2 mating marks on the chain, on the driverside/passengerside are there?
The FSM shows 8 links & 16 pins for the driverside.(At least thats what it looks like magnified)
If I've overlooked this information somewhere in the various "Timing Chain" posts, Please feel free to post a link.
Raxephon
Well, since no one could answer my "Q", I decided to strip her back down & see for myself.
Both chains are the same.You do not count the actual silver/gold link, just the number of plates/pins between them.
Space between cam sprockets: 8 Plates/16 Pins (Odd & Even Cyl.'s)
Space between Odd Cylinders Intake Sprocket & Crankshaft Sprocket: 25 Plates/ 48 Pins
Space between Odd Cylinders Exhaust Sprocket & Crankshaft Sprocket: 24 Plates/ 50 Pins
Space between Even Cylinders Intake Sprocket & Crankshaft Sprocket: 24 Plates/ 48 Pins
Space between Even Cylinders Exhaust Sprocket & Crankshaft Sprocket: 25 Plates/ 50 Pins
Hope this is of use to someone else as well.
Modified by anlasak at 7:50 PM 10/17/2005
Raxephon
Oh Yeah. Bump
Modified by anlasak at 8:32 PM 10/17/2005
Raxephon
And the other side
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Great information for the Articles Section.
Raxephon
maxnix wrote:Great information for the Articles Section.
Just trying to contribute
Raxephon
Edited due to redundency of question.
Headbolt notches will face inward on both heads.
Cam lobes for Cyl#1 will be opposing when Piston#1 and the crankshaft pulley are set at TDC.
Modified by anlasak at 4:03 AM 12/30/2005
Return to “VH45DE / VK45DE / VK56DE Forum”
