Camshaft sensor plug, Where does it connect
JZX91-2JZ
Car: Nissan Infiniti G50
Hey guys just done a service on my Q45 its a 93 model and noticed on the drivers side (by air box) camshaft sensor plug is not connected. Where does it go?
Q45tech
90-93 CAS has 2 separate connectors whereas the 94-96 has ONE connector.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
JZX91-2JZ wrote:my Q45 its a 93 model
If you include this information, model trim (standard, t or a) and location in your profile, we can help you a little better and you don't have to repeat it every time.
unknown007
Car: White 1993 Q45 (G50)
maxnix wrote:If you include this information, model trim (standard, t or a) and location in your profile, we can help you a little better and you don't have to repeat it every time.
Dude STFU.
Like Q45tech said both sides connect separately.
JZX91-2JZ
im aware that both sides connect separately. But where on the drivers side does the plug connect too?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
unknown007 wrote:
Dude STFU.
Ignorant doods like you soon pass as soon as they wreck their cars by working on them.
You'll be migrating to Mexico for work soon.
JZX91-2JZ
Come on fellas lets get back on topic and help a noobie out!!
jimbyjimb
Car: 1992 Infiniti Q45
The sensor is known as the CAS, Crank Angle Sensor, and is a big sensor with a black cap on it saying Nissan and has a Mitsubishi emblem on it as well. There is a small connector on the side facing the charcoal canister/drivers side front wheel. There is another connector above that is larger and grey in color, it should be mounted underneath the plastic cover inbetween the valve covers on the front of the engine just behind the belt-driven cooling fan. If they are indeed plugged in then I would suggest cleaning with a wire brush and/or sand paper and electrical contact cleaner. Only use grease after confirming the sensor works as I have seen grease impair conductivity as it is an insulator.
