Have you checked the harness connection? Even JiffyLube would have to go far out of their way to damage the sensor itself. Yanking on a harness is easy.
gordonq45 wrote:I believe the CAS problem has been fixed after cleaning up the connectors and putting di-electric grease on them. It has been few weeks and has no problem so far. THANKS AGAIN FOR EVERYONE'S HELP.
One exprience can share with you!
Last weekend, I can not start my car after refueling my car and back to my home. I searched the threads about this problem that most point to fuel pump problem. I use the same philosophy provided by Q45tech to check the wire first. I open the back trunk and disconnect and reconnect the connectors of fuel pump and fuel controller ( I DO checked the connector pins and they are ok, not rusted) . The problem is gone after reconnect them. So far it is ok.
SO, WE CAN/SHOULD CHECK THE WIRE AND CONNECTORS FIRST BECAUSE THE CAR IS GETTING OLD AND CONTACT COULD BE A PROBLEM.
One more issue on my car is idle. The idle is pretty low if the gear moved to Drive/Rev position, about 500-530, after the engine reaches to normal tempreture. At P/N position, the idle is ok, about 700.
Please give a suggestion to find out the reason of this issue.
Thanks,
