VNG704 »
https://forums.nicoclub.com/vng704-u103769.html
Fri Apr 17, 2009 5:52 am
Yes, I'm going to be using this head until I get my next head. I found a replacement head with no cam caps. This is the head I'm going to use my hks cams in. Would my old cam caps be fine with this or would I need to buy new ones? Going to install that oil pressure gauge I got sitting in my room to watch the oil pressure because of that sanded down part. As far as torqing this, I just tighten little by little and finish with the 6.7-8.7 lbs-ft per FSM. FSM was asking for 1.4 for step 1, then 4.3 for step 2, I couldn't find a torque wrench with anything smaller than 5ft-lbs.
