Camshaft positon sensor
crimsone96Q45
Car: 1996 Q45
morning all. had the car coded after the cel came on and its now giving me a camshaft position sensor, is this why the car seems to kick back down instead of staying 4th gear, not a hard kick but i can tell it doesnt want to stay. what the heck is this , has anyone had to replace it, what does it cost from joe ( their price is 450.00 ) where is it located ?
Thanks
Q45tech
Usually dirty corroded connectors not the unit itself.........clean with crc contact cleaner a few times and see.
crimsone96Q45
Car: 1996 Q45
really ?? ok that sounds like a plan tech, so the real question is where in the blazes is it. someone told me that it was ontop of the trans housing
thanks for the tip
Q45tech
The camshaft position sensors [CAS] bolts to the front of the drivers side exhaust cam external to the engine head.
The turbine sensor is atop the transmission.
Download the 96Q manual and spend a few days memorizing the first 300 pages.
crimsone96Q45
Car: 1996 Q45
thanks tried to download the fsm but couldnt get it to load for some strange reason, keeps trying to use excel to do the down load. wtf ? any way i will go and take a look for it today. any prior links here with that info. thanks for getting back to me so soon tech.
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
If the FSM is in a PDF format, make sure you have Adobe Reader installed on your pc.
http://www.adobe.com
crimsone96Q45
Car: 1996 Q45
hi louiegz. tried to use adobe still wont work said that the file is corrupt. im just trying to find out where the cam position sensor is located. im going to order the cd from another nico member. thanks for the input
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Did you download it from phatg20.net? If so, you need to get winRAR.
