Justin35ll »
https://forums.nicoclub.com/justin35ll-u118020.html
Wed Jan 28, 2009 7:27 pm
Well even if you did tighten it down like that you still need 9 links between the cam marks.I kinda had this problem too, but not to that extent.
Just make sure you're on TDC cyl 1 and set the marks down next to the cam to 10 and 12, not the chain link marks
Also the way you tighten down the cams is like this
9 5 1 3 710 6 2 4 8
But instead of starting with 1 and 2 you start by tightening down 9 and 10 then continue through 1 - 10. So that may help you keep the cam in place where you want it.
I forget factory torque spec somewhere around 7.8 or something.I would do a first round of about 4ft/lbs then a second round of 7.8ft/lbs
So take all your cam caps off and set the chain links where they need to be set the cams where they need to be and do as I said above
