Too much hassle when you can get better aftermarkets for cheap.C - ROD wrote:well im speaking of the ones from rwd sr20de
You stand to gain midrange on a stock turbo but thats about it. Flow is limited by the turbocharger.C - ROD wrote:this i know but i was just wanting to know
I'm sure HKS, JWT, and a number of other manufacturers are aware of overlap. Besides, my point to him was that you don't stand to gain much with a camshaft upgrade on an engine with a tapped out turbo.VitaminT wrote:I am not sure about stock na cams, but usually aftermarket cams have more overlap than turbo cams and can hurt spool times ect. Granted the lift and duration might be slightly more, overlap isn't really spec'ed out.
yea, and if your only running stock boost you won't "lose" power but you aare sacrificing a good amount of lowend for a minimal amount of highend.HardcorePS13 wrote:
If you are running stock boost you will notice a considerable amount of top end.spider_slayer wrote:yea, and if your only running stock boost you won't "lose" power but you aare sacrificing a good amount of lowend for a minimal amount of highend.
no.HardcorePS13 wrote:He would gain 20whp if he were running stock boost.
Incorrect.spider_slayer wrote:no.
like i said, you will gain SOME top end but NOT 20whp. if you don't believe me then get your self some step s 272/272's and dyno then prove me wrong.
its really not worth losing your lowend.
this has been discussed many times by the way. hey look i found this by searching zerothread?id=55568
You will gain a good amount more power than you think as I've stated and elaborated on above.spider_slayer wrote:ok, i understand what you are trying to say. and that link was probally a bad example because it refers to running 12-14psi. but you are still not going to gain 20whp with upgraded cams. the stock cams are matched to the stock boost to provide the best balance of lowend and top end. even if you do gain that 20whp you lose a good amount of low end power.
I'm not telling him to go out and buy camshafts. Read my posts.spider_slayer wrote:besides why spend upwards of 400 on cams when for around 150 you can buy a boost controller and a fuel pump and run full boost and stand to gain ~30rwhp.
