Cams
boke_as_hell
Car: 92 240sx hatch
I know this is a repost in a way. I seached the archives for cams to use on the KA-T, but didn't find a definite answer. So ... I'm gonna ask what are you guys using in your KA-T?
hannibal
Car: Red Line to Glenmont
1. S13 cams (if you have a S14)2. dual S13 exhaust cams3. PDM (made by Colt?)4. JWT5. Gude??6. custom...
boke_as_hell
Car: 92 240sx hatch
that's awesome...some idiot that's ricing one out, threw 2 not not 1 but 2 rod threw the block, but the head was untouched other than the intake cam snapping...so i have 2 S13 exhaust cams. Thanx for the info.
hannibal
Glad I could help with my limited knowledge 2 exhaust cams are good for the top end, but hurt spool up/low end slightly. I'm planning on trying S13 int and exh (240/248). Ive also heard of guys using the S14 232 intake cam with the 248 exh cam.
I have a question...What is the goal in selecting cams for a turbo motor? Are you going for high lift and long duration while avoiding too much overlap?? I guess I'm asking how the motor is effected by changing intake and exhaust cams.
I understand top end improves (while low end suffers) when going from 232/248 to 240/248 to 248/248. But why doesnt anyone use a 240/232 setup??
nonchalant rage
Car: s12
boost designs also has 2 different sets of KA cams.i believe crower is working on putting out as many as 5 camsets for the KA, ,
Veriest1
Car: '96 BMW M3
'93 Nissan 240SX coupe dd
Here's some information I got in this thread zerothread?id=103095
This is a direct copy and paste of SimpleEnigmas post; hopefully it will help you out a bit.
1.) Consider your application....race cams on a fairly stock daily driver = rough idle, questions from the cops, and doesnt always mean big gains.
2.) Lift......the depth the valve drops into the cylinder....generally the more lift, the greater the volume of air the valve can get through it before it shuts. Huge lift is not always the best way to go.
3.) duration and overlap....duration is the amount of "time" (degrees of rotation) that a cams lobe holds the valve open (i.e 274 duration means that for 274 degrees of that cams 360 degree movement for one complete rotation, the valve is open.) The longer the valve stays open, the more air can enter the cylinder.....again, consider your application....big duration usually mean large overlaps between the intake and exhaust cams. Overlap is the amount of rotation in the intake and exhaust cams where the I/E valves are both open simultaneously. This generally takes place when the piston is pushing exhaust gas out of the cylinder. The overlap is used to make intake air help push exhaust gas out and at the same time aid the intake air in entering the engine more efficiently (think along the lines of a vacuum, as the exhaust gas exits, the incoming fresh air is pulled into the engine by the vaccum created by the exiting exhaust gas). This makes engine have to work less to draw air into the cylinder. This helps reduce parasitic power loss (the less work an engine has to put in to running itself the more efficient it is) and improves hp gains......once again, everything in moderation....huge overlap is not always the answer....
Your application is the number one item to consider when choosing a cam setup. NA and Turbo setups dont like the same cam grinds. Huge overlap in a set of turbo cams actually helps to defeat the function of the turbo by allowing some of the compressed air to completely bypass the cylinder and exit into the exhaust header, wasting the air. Cams with little or no overlap arent good in NA setups because the overlap aids the piston in expelling exhaust gas and improving engine efficiency.
So can someone expand on that maybe?
nonchalant rage
Car: s12
it should also be noted that duration should be measured at .050" lift, if its any less the company is probably just trying to make the numbers seem big.
hannibal
Veriest, thats good info you posted.
I should have searched
Veriest1
Car: '96 BMW M3
IWannaS15 wrote:Veriest, thats good info you posted.
Eh, I just happened to remember where the thread was and didn't figure you would search for info concerning NA cams.
Red-KAT
Car: 1995 240sx-se ka24det
That's why the PDM turbo cams are short duration large lift... Good for turbo.
STOCK 91 Cams - Intake - 207 degrees duration @.050”, .350 lift; Exhaust 215 duration @.050”, .367 lift.
C.702.S Stage II Cams - Intake 221 duration @.050” .379 lift; Exhaust 231 duration @ .050" lift, .390 lift
C.702.T STAGE II DOHC Turbo Cams – Intake 221 duration @.050”, .380 lift Exhaust 221 duration @.050” .380 lift
Red-KAT
I did a search and cant find info...
Whats the Stock DOHC spec's?
hannibal
91-early 93 S13240 int/248 exh
late 93-98232 int/232 exh
i dont know the complete specs (what lift, etc). FSM doesnt say but it sounds like Nissan is cheating a little bit.Anyone notice the S13 FSM says 248 intake and 240 exhaust??
IvanAtSPRacing
Car: I make cars fast
Crower does have cams. I have two and 1/2 sets in stock.
Stage II Turbo camsIntake and exhaust are the same spec211° @ .050" with .397" lift
I have been waiting on them to finish the valve springs and Ti retainers so I can get them into the R&D S13 head to do the Crower V Stock cam dyno testing. They finally got the spring seats done and shipped them out to me. I believe I will see them tomorrow.
I hope to have the car on the dyno within the next couple weeks.
Modified by IvanAtSPRacing at 10:02 PM 3/3/2005
Modified by IvanAtSPRacing at 10:55 PM 3/4/2005
NateDogg
I tink he meant "Crower" not "Flower". Interesting note on the specs though.
Red-KAT
I’m secure with my masculinity and all… But if I were driving around with “Flower” cams people would suspect some serious wrist flicking action out of me…
Anyways... I would like to see some Dyno #'s from you Ivan... In a normal 10psi type of car... But some Dyno beast would be fine too.
Ubernoober
Just as a bit of clarification to Veriest1's excellent post....
the "degrees" of cam duration are calculated in CRANK degrees. Which on a four stroke is 720 degrees of rotation for a single engine cycle. So a 270 degree cam holds the valve open for 270 degrees of crank rotation. You will find this makes much more sense when you try to calculate overlap, lobe ceterline and lobe separation angles. A LOT easier.
turtl631
Car: S14
As a side note, a member on freshalloy i believe has had a turbo ka for like 4 or 5 years and experimented with pretty much every cam combo. He found 248 intake/232 exhaust to work very well for all around use and a balance of top end and midrange. I also know that rick (533 whp s14) tried dual 248s and didn't gain anything...maybe too much overlap? the 248/232 setup is what I want to do, and you only need one s13 exhaust cam then too.
