Cams power under the curve
maniacmcgee
Car: 1995 240sx ka24de-t
8.6 to 1 supertech
h-beam rods
pt5858cea bb
id1000cc injectors
jwt s1 cams and jwt gears
nistune
ok so i looking for cam specs for a ka-t. not stock specs or swap specs. im looking for acutual specs on aftermarket or custom cams with maybe some dyno proven. i have a ka24det and am looking for power under the curve. trying to keep to 2000-6500 rpm range to play off the torque of the motor as much as possible. ka24det 8.6 to 1 pistons h beams 740cc intectors t3/t4 t04e 15lbs custom tuned ecu 3in exhaust. sorry for rambling
dyno proven cams specs any help ideas
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
You'll probably want a 264 cam then. BC makes an iffy set, I hear good and bad about them,
Kelford makes a 256/264 setup but I haven't seen any numbers yet. http://www.240sxmotoring.com/kekast1ca.html
Search bc264's and you should find several dyno's, but I really believe the Kelfords will make better all around power, they make very good cams.
