Dead on. Coilovers are for serious track folk, not for your run of the mill project car for driving on the street.charlieo wrote:Buying coilovers you'll never cornerweight or tune in any other way IS a "Honda" thing. Save your money, buy lowering springs instead.
99% of stuff done to street cars is done for bragging rights. Nobody needs a bigger turbo to get to work or a test pipe to drive to Safeway. It's basically all done so that they can put stuff in their message board signature block or talk about it when they're hard parking.numbnuts240 wrote:see that makes sense...s***, i almost asked why it's done so much on street cars, but it's just bragging rights after that.
well they are nice because they give you a shock that is designed for the spring rate & height of spring they are being used for, and most often camber plates and solid upper mounts with height adjustabilit, and you don't have to thing or match compatible parts...MinisterofDOOM wrote:
That's what I was thinking. Coilovers are certainly not the only suspension option. If all you're after is a drop, springs and shocks are fine. Spend the money you save on some poly bushings and your car will feel like a whole new machine.
Most cheap coilover sets are the same inserts packaged into different hardware and spring rates. Rarely are they correctly matched to spring rate or length.Red coupe wrote:well they are nice because they give you a shock that is designed for the spring rate & height of spring they are being used for, and most often camber plates and solid upper mounts with height adjustabilit, and you don't have to thing or match compatible parts...
But for a similar price, or maybe a LITTLE bit more you could likely put together a better set up overall if you took the time to figure out what you were doing, and call some suppliers for help.
That said, coilovers (or equivalent) isn't really only for track cars. Sure, preload adjustment is likely to be ignored by just about everyone... but adjustable shocks are very nice and even if you aren't using them to get every last 10th of a second they really help to make the car fit you and drive the way you want. It doesn't take 10/10ths driving to enjoy a decent suspension set up.
Hi. You know I was big into RX-7s, right? They're like 240SX's, but faster and sexier and less tolerant of idiots. Back when RX7Club.com was good and not owned by some soulless corporation, Good-win Racing had a big writeup on coilovers, the product of their quest for good budget coilovers to sell. Everyone of them was junk. The valving was so far off for most of them it was clear how the companies mix and match inserts and springs. You know what they settled on? Koni Yellows and Ground Control spring perches. They've since gotten out of the FC business because nobody wanted to pay the extra money for quality when Megan made ZOMG $600 coilovers!Red coupe wrote:Buy cheap s***, get cheap parts.
By the way, where are you getting this from? Anything to back it up or just trust in the internet?
edit: Most cheap coilovers will also use the same spring rate and spring length too, so even with parts bin shocks it will still match.
Not saying that every cheap coilover does a good job of matching it. Ask a 4 year old to machine you a shock mount for you and you will get crap. Ask a korean company to make as many as possible for the cheapest price and you will only get slightly better... Ask a good company and you will get quality. That s*** should go without saying.
My point is that you did pretty much whip that fact out of your a**, or at the very least based it off assumptions and message boards. How many 240 coilover kits have you held in your hand, and how many do you know the suppliers of each part for?
Modified by Red coupe at 2:02 PM 2/9/2010
Plus I mean a quick googling will reveal ride problems with cheap coilovers of all sorts. Struts that are correctly valved for a spring rate won't pogo like the budget aesthetic coilovers are prone too.NASIOC wrote:First - if you have to ask, you probably don't need coilovers. This is the Rule of Biggly (tm).
the coils wouldnt be to just make it lower but to handle better tooasoomal wrote:Cams.
How gives a crap how low your car is.
Lol, so basicallycharlieo wrote:Hi. You know I was big into RX-7s, right? They're like 240SX's, but faster and sexier and less tolerant of idiots. Back when RX7Club.com was good and not owned by some soulless corporation, Good-win Racing had a big writeup on coilovers, the product of their quest for good budget coilovers to sell. Everyone of them was junk. The valving was so far off for most of them it was clear how the companies mix and match inserts and springs. You know what they settled on? Koni Yellows and Ground Control spring perches. They've since gotten out of the FC business because nobody wanted to pay the extra money for quality when Megan made ZOMG $600 coilovers!
This. And carefully dancing around Quote »How many 240 coilover kits have you held in your hand, and how many do you know the suppliers of each part for?[/quote] the fact that the answer here is 0 by acting condescending.Red coupe wrote:you did pretty much whip that fact out of your a**, or at the very least based it off assumptions and message boards.
Oh yeah sure. The Chinese put extra care into the 240SX coilovers because they know you own one!Red coupe wrote:
Lol, so basically
This. And carefully dancing around the fact that the answer here is 0 by acting condescending.
Yes, I know you used to have an RX7. No, I did not know you were "big into them"... I though you just owned one, and read s*** off forums to recite on other forums.
Do you seriously think that it would?charlieo wrote:Also, I spent several hours drunkenly observing Koni techs rebuild shocks and struts at 3 Rolex 24s... does that count?
Well what with state dependent learning and all...Red coupe wrote:Do you seriously think that it would?
If so... I am kinda worried about you man.
already got upper and better lower sway bars, all bushing r good they dont look all dry rotted or busted up (thought about getting stiffer ones but would like it to sit lower and lose some of the rollover effect)asoomal wrote:I doubt GodSpeed coils will make it handle better.
I'd rather do all of my bushings, including the subframe ones and adjust the alignment. Also, get some beefy sways.
I second this. Tok Illum's aren't bad either for a drive-around performance shock.Dattebayo wrote:For what it's worth, KYBs hold up pretty good for what they are. Your kind of driving won't kill those things... as long as you don't go super low on the drop, that is. I think 2 inches is the most?
